TCP transfer data
Hi all. I have a big problem. I must to transfer data from Labview with TCP in C#( TCP server). I am using this  code https://msdn.microsoft.com/en-us/library/system.net.sockets.tcplistener(v=vs.110).aspx . If i put one breakpoint at this line
 while((i = stream.Read(bytes, 0, bytes.Length))!=0)
and press F5(continue) i can receive data from Labview program but without breakpoint, there's no data transfered. How cand i obtain same result without stop for brekpoint?
Thank you so much.
(3,130 Views)
Accepted by topic author Claudinho18
It was to quickly. I tried to wait in Labview but no effect. I put a timer on C# and work fine.
(3,102 Views)
