formula node to integrate
good afternoon,
i need a help from anyone regarding writing a function .i need to integrate a function but i cannot find the right syntax to do so. CAN i do integration using formula node or need to use math script? wat is the syntax for integartion? hope can get a simple example thanks?
(5,441 Views)
What is your function or formula? You can calculate almost any formula using LabVIEW functions, but some people prefer the formula nodes.
Robot wink
(5,414 Views)
K * (1/S)
(4,638 Views)
Hi Mesqunu,
this formula looks like a simple multiplication to me...
Where is your"integration" part?
(4,630 Views)
No, there is no array integration in formula node functions. Math script or integral.vi
(4,621 Views)
I don´t understand why the following integral ( Untitled_integral.Vi )shown ' 0 '. Can you help me?
(4,605 Views)
Your array is initially empty, and no multiplication or addition will magically append elements to it. Turning an empty 1D array into a 2D array using "built array" just gives you you an empty 2D array.
Are you trying to append new data to the existing array? In that case you need to hook things up quite differently, but then you should also not run this loop as fast as the computer allows or you'll run out of memory very quickly.
Start with some tutorials. You'll figure it out!
(4,601 Views)
