TCPListen Connection Poblem
Python 3.6
import socket
def Main():
    host = ''
    port = 49157
    mySocket = socket.socket()
    mySocket.bind((host,port))
    mySocket.listen(1)
    conn, addr = mySocket.accept()
    print ("Connection from: " + str(addr))
    while True:
            data = conn.recv(300)
            if not data:
                    break
            print ("Data: " + str(data))
    conn.close()
if __name__ == '__main__':
    Main()
Message 11 of 12
(532 Views)
The solution was to set the input "resolve remote address" of the TCP  Wait on Listener to false. Default it is true and it asks after the name of the ip out of the dns, but when there is no name, after 4-5s it gets out an LabVIEW gets the connection id and can read it.
With false on resolve remote addres TCP Listen doesnt want to read the name of the ip and i get a fast connection.
Message 12 of 12
(455 Views)
