TDM file problem
I want to export my acquisition data into TDM file.
Now my question are :
- How to save continuous sample data acquisition into TDM file? Because the TDM file create a new tab for each sample per channel ( block size ).
- How to edit the channel name? I have try to change the channel properties but it´s not working.
I also attach the my VI, tdm file and the configured properties.
Any suggestion and help are welcome Smiley Happy
Citra
(2,750 Views)
Try to place the Write To Measurement File outside the while loop.
So it only executes once, at the end of the procedure.
Like that you will generate a file with 6 channels.
regards,
adigator
(2,720 Views)
duplicate post I don't know if you are the same person with two different user names or two different people working on the same project. In either case, your behavior is inappropriate.
(2,713 Views)
