TDMS Add-in for Excel stopped working
Excel 2007
Message 11 of 20
(1,983 Views)
2003
Message 12 of 20
(1,971 Views)
I am trying to reproduce this issue, did this happen after upgrade to LabVIEW 8.6 and an upgrade of the toolkit? What version of LV did you upgrade from?
--Michelle
Message 13 of 20
(1,953 Views)
my intuition from what happened when mine stopped working tells me that something went wrong with the TDMS buttons that excel displays because they were still there in excel but when pressed nothing would happen.  I can't imagine that a LabVIEW upgrade would have affected anything to do with an excel plugin.  Mine did the same thing and i have never upgraded LabVIEW.  I think its more of an issue with excel and the plugin.
Message 14 of 20
(1,945 Views)
Mine just stopped working again?????
Message 15 of 20
(1,943 Views)
haha, document it!  what happened EXACTLY?
Message 16 of 20
(1,941 Views)
Ok, it doesn't work when I am logged in as a regular user but does work when I am logged in as an administrator. According to IT I am not allowed to work while logged in as an Admin which doesn't help but sounds like there might be a permissions issue or something. When logged in as a regular user the buttons just don't work.
Message 17 of 20
(1,931 Views)
interesting.  if you delete the plug in and then reinstall it as a regular user can you use it again?
Message 18 of 20
(1,929 Views)
Have you tried:
Troubleshooting the TDM Excel Add-In for Microsoft Excel 2007
My dll was located at
C:\Program Files\National Instruments\Shared\TDM Excel Add-In\
or
Troubleshooting the TDM Excel Add-In for Microsoft Excel 2000-2003
Try removing the plugin and then adding it back again.
Does this work for anyone?
--Michelle
Message 19 of 20
(1,911 Views)
Have just been through this after a nasty Labview Install,
I went to manage the Add-Ins and it was listed as disabled.
Enabled it and all is well again.
iTm
iTm - Senior Systems Engineer
uses: LABVIEW 2012 SP1 x86 on Windows 7 x64. cFP, cRIO, PXI-RT
Message 20 of 20
(1,399 Views)
