TDMS File starts recording data at 20Hz, but after a short time drops to <10Hz as VI slows, why?
How can i find where this is happening? basically if I open my tdms file after about an hour, the first few thousand samples are 20/sec, but then it slowly drops down to 19/sec 16/sec, etc. I am reading and displaying data from two serial-usb ports over VISA. The vi graphs and counters themselves also appear to be slowing. I have preallocated my graphs with 1000000 sample arrays, and am using queues to shuttle everything around what is it I am missing?
I cannot post the code it is proprietary unfortunately.
Message 1 of 34
(4,574 Views)
Then it's very unlikely that we'll be able to help you. It sounds like a memory allocations problem - but without seeing the code to look for growing arrays/queues, it's virtually impossible to 'guess' at what the problem might be. Is your memory growing? Have you used the desktop execution trace toolkit and turned on the 'display allocations' option?
(blog)
Message 2 of 34
(4,560 Views)
How Can i query the queues/arrays to find out if they are growing? Is there an analyzer function like in Matlab?
Message 3 of 34
(4,556 Views)
I edited my post - you can use the Desktop Execution Trace Toolkit to view memory allocations.
(blog)
Message 4 of 34
(4,553 Views)
I attempted to scrub as much identifying info as I could.....thank you for the help
Message 5 of 34
(4,531 Views)
TDMS files get continually slower when adding small amounts of data/groups/channels due to limitations of the implementation.   I had a similar problem (albeit a different magnitude).  Try writing fewer chunks of data. Avoid point by point writing at all costs.
Shane
Message 6 of 34
(4,487 Views)
What do you mean write fewer chunks of data?
Message 7 of 34
(4,439 Views)
Every time you call a TDMS write or a TDMS Advanced write, data is written as a "chunk".  Next time you want to write, the driver does a linear searcht through all chunks to find the next write position.  As you can imagine, if you have many many chunks, write time deteriorates continually as the search takes longer and longer.
You can read about my own problems HERE where NI eventually (it only took a few weeks) admitted it was an issue with the file format and that my data was not "typical".
Message 8 of 34
(4,431 Views)
So I don't care when the VI writes to file, but I do need it to display at 20Hz on all graphs. Is there a way to store in a buffer the "chunks" and then write them to a tdms file with a lag such that it does not slow the whole VI down as time passes? As long as when I hit the stop button and open the tdms file in excel, there is data in all columns at 20 samples/second I don't care when it wrote down that data (real time or delayed).
Message 9 of 34
(4,421 Views)
If you are using a Producer/Consumer, it is very easy.  One way is to recieve multiple elements in your queue and then write all of them in a single TDMS write.
Message 10 of 34
(4,414 Views)
