TDMS File starts recording data at 20Hz, but after a short time drops to <10Hz as VI slows, why?
One option that I have done before was write a FIFO buffer as an action engine.  I stored about 1/2 hour of data in the buffer always, with  "Add Data", "Read New Data", and "Read Historic Data" commands.    I could then have my data save loop run at a very slow rate with automatic bunching, with the added option of recovering / saving 1/2 hour worth of data if ever needed.
Message 11 of 34
(2,596 Views)
@crossrulz wrote:
If you are using a Producer/Consumer, it is very easy.  One way is to recieve multiple elements in your queue and then write all of them in a single TDMS write.
Aren't I doing that now in the code I posted? I have a cluster of elements the queue, are you saying lose the other two writes, and recmombine them later? This is the code i posted earlier that is slowing down:
Message 12 of 34
(2,588 Views)
Yes.  So with your top loop, put the dequeue inside of a FOR loop that can stop when there is a timeout.  The reason for the FOR loop is to log multiple instances at once.  I would set N to be something like 10 (or more if you can afford to wait longer between writes).
Message 13 of 34
(2,580 Views)
And looking at this code again, we should combine the two string writes into a single write, like we are doing with the numerics.
Message 14 of 34
(2,576 Views)
How do I combine them but keep them appearing in the right columns like they are now? I made them separate since I needed the headers to appear in excel a certain way when I opened the TDMS in excel.
Also am I doing a best practice by having double queues, one for VISA and one for data? Should I move the VISA just into the main loop with all the graphing? would that save memory/prevent slow downs?
And did i implement the array preallocation correctly in the main graph?
Message 15 of 34
(2,567 Views)
Well, if that is a requirement, then nevermind.
That is what I do.
Message 16 of 34
(2,553 Views)
Thanks, I will give the for loop a try and run the program again, if it still does not result in 20sample/sec data recording/display am I just SOL?
And when you say that is what you do, do you mean keep two queues or VISA in main loop?
Message 17 of 34
(2,547 Views)
I have what I call "modules".  In your case, there is an instrument module, a processing module, and a logging module.  Communication between loops is done with queues, just like what you have now.
Message 18 of 34
(2,541 Views)
How did you get the stop sign in the for loop? Nvm I got that.
I am getting the error REfnum became invalid while the node waited for it. if the for loop is in the code and i hit the stop button. what does that mean?
Message 19 of 34
(2,508 Views)
Well, you are trying to stop this loop by destroying the queue.  So that makes sense to me.
Message 20 of 34
(2,496 Views)
