TDMS List Contents: group name is an empty string
Hi!
TDMS List Contents VI : if the input "group name" is not wired, VI returns an array of group names. In my application the first element of this array is an empty string. Is there any reason for this? Or my application creates erroneous TDMS files?
Thanks.
(3,810 Views)
Accepted by Ljubo
Hi Ljubo,
the empty group name is for the file. Why it is done like this i do not know.
When you only want the groups then you must skip the first element.
When you list the channels of a group, an empty string is returned too. This one is for the group itself.
Greetings,
shb
(3,801 Views)
Thanks Ljubo. I wish they would put that in the VI documentation.
[will work for kudos]
(3,540 Views)
In LabVIEW 2009 the empty string is no longer returned.
(3,440 Views)
