TDMS creating new files
Hello!
I know that using the "Write to Measurement File" it's possible to select the option "Use next available filename" when a file already exist, so each time the program runs it'll create automatically a new file. Does someone know if I can do the same but with using the normal TDMS tools? I've tried modifying the Operation option of the TDMS Open tool (Open and Create, Create and replace, Create), but although I write an initial path for the file, everytime I run my program the data is being replaced or being written within the same file, it doesn't create a new file automatically, as I need it.
Thanks for your help! 😉
(2,818 Views)
You can do some think like the example attached.
Anderson M. Takemoto
Instituto de Pesquisas Eldorado
(2,809 Views)
uhh... thanks, but there's no attachment Smiley Surprised
I'll wait for it 🙂
(2,801 Views)
Accepted by LinaZ
Sorry! Now it here!
(2,786 Views)
Hello!
It worked! it's a little more complicated than I thought, but I could understand the "trick" to change the path 😉
Thanks a lot!
(2,775 Views)
