TDMS for noobs?
I am currently working with already developed LabView application (we are locked out of the code). The program records from a camera and is in-sync with accelerometer data per frame (2000 frames per second). The program creates a TDMS file.
I am solely interested in one of the axis on the accelerometer data. Is there a way to go into the TDMS file and just pull out what I what and export it to excel?
I'm sure the whole process is a lot more complicated, but can anyone help?
Cheers
Kamilan
(3,063 Views)
With this add-on, you can load the TDMS file directly in Excel. No programming required.
Jarrod S.
(3,054 Views)
Accepted by Kamilan
Kamilan,
            There is a TDM Excel add on available here http://zone.ni.com/devzone/cda/epd/p/id/2944. You can export TDMS data to excel. Other option would be to write a simple VI to read the TDMS file and save the desired channel data in spreadsheet file.
Kudos are (always) welcome for the good post. 🙂
(3,052 Views)
Oh wow. Downloading the exe now. The TDMS files are at work. Will let you know how it goes Monday.
Thanks for the help guys!
Cheers
K
(3,032 Views)
odessy27 & Jarrod S.
Thank you so much. Bloody Brilliant!
(2,985 Views)
