TDMS minimum buffer size
Hi all,
cRIO streaming benchmarks
Setting NI_MinimumBufferSize
It seems that for efficient streaming to disk I need to be writing in blocks of ~1MB, Rather than concateneating data points and then writing large blocks to disk it looks like the TDMS buffers can be set on a channel by channel basis.
BUT... what is the unit of the property NI_MinimumBufferSize?? is it bytes or data points?
Steve.
(3,819 Views)
Hi Steve,
The unit is "data values", this property indicates how many (or the number) of data values.
(3,814 Views)
