how to run my program for 0.6 seconds?
I have to obtain magnetic values for ferromagnetic materials using labview and two thyristors.
What i have: I have built a comparator on labview which will compare a mains voltage and my ref voltage. The mains volatge is carried into the VI via a daq assistant. the outcome (voltage) is then passed to th two thyristors, once again via a daq. The thyristors will then pass the voltage along to the magnetic circuit for only!!! 0.6seconds?? as voltage from the mains is very powerful. this is a university project where i work supervised in a lab. Thank you
(2,897 Views)
What type of DAQ interface are you using? That changes the options for how to control the timing.
Jason
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
(2,892 Views)
Thanks for getting back to me.
i have been on holiday so sorry for the late reply. im am using a USB-6000 series prototyping accessory the only one available at university. does this help?
(2,852 Views)
(2,823 Views)
