TDMS write performance
Dear community members,
I've been working on a CompactRIO project for about 2 months now. I've started with zero experience with LabVIEW and thanks to the large amount of tutorials and these forums I've been able to get everything I needed to work so far, so thank you for that! Unfortunately though, I'm running into issues with CPU usage on the cRIO system at the moment.
My current system reads out 9 values from various sources (temperatures mainly) at a rate of 100S/s. These values are moved into a RT FIFO Shared Variable and logged using the Producer-Consumer principle. The system can aquires this data just fine without logging while using roughly 36% CPU. When I turn logging on, the usage goes up and stays at 99%. I figured I was writing too often, so I increased the buffer size and started logging at 50Hz instead. CPU was still 99%. Then I moved to logging at 10Hz, CPU still at 99%. However, when I look into the TDMS files I find that I am not missing any samples.
When I search the internet for relateable issues I find people logging arrays 100 times the size of mine at rates running into the kHz region before they run into trouble. I feel like I am missing something obvious here but I can't find it. I've attached the code. I've added some notes in the code as well which relate to my troubleshooting attempts. My apologies for it being a bit of a jungle perhaps - the problem should be inside the first case structure inside the big main while loop.
TL;DR: Only logging 9 channels at 100S/s in TDMS, CPU at 99% whatever I do. What am I doing wrong?
P.S.: The Shared Variable 'disc data' is Array of Double, RT FIFO Multi-Element with Number of Arrays: 200 and Numer of Elements: 9.
Message 1 of 11
(5,997 Views)
How did you change the logging rate?  Besides, since you have the FIFO turned on, it is so that you will not miss any data.  So you are logging as fast as you can trying to get all of the data.  I do not think you actually want this.  From what I can tell, you just want to log the current values.  Therefore, I would turn the FIFO OFF on the shared variable and add some sort of wait in the logging loop.
Message 2 of 11
(5,978 Views)
The logging rate should be controlled by the timeout value in the Shared Variable read block. If I diable the FIFO I will most likely miss a few values since I can't oversample some of my thermocouples. Either way, does that mean this is simply the best the cRIO can do?
Message 3 of 11
(5,918 Views)
Accepted by Ruben92
Not true.  The timeout is just how long to wait for data to enter the FIFO if it is empty.  So if there is data in the FIFO when that node is called, it will immediately return the next item in the FIFO.  You are not throttling the loop at all.
That makes no sense at all if you set the logging rate.  If you want to log the current data every 50ms, then you will not log all of the data.  If you absolutely care about every single value, then just use a normal queue.  It is easier to understand and works more efficiently.  There are also tricks to read the queue until it is empty and then log the bulk of data at once.  This will help your performance some.
Message 4 of 11
(5,901 Views)
Unless he means sending the data to the consumer loop at full rate and accumulating the data until writing every X ms.  This decouples the disk activity fromt he primary data source a little, perhaps resulting in better performance if teh disk is truly the limiting factor.
But as an aside: Are you opening and closing the file each write?  That will slow things down considerably.  You should be able to stream faster than that.  What file format are you writing to?
Disclaimer:  I an't open the code, I only have LV 2012 so my comments may be way off track
Message 5 of 11
(5,875 Views)
@Crossrulz
I see, I misunderstood the function of the timeout feature. I'll throttle the loop with a wait function instead and see how it goes. Also like you said, I'll try using a queue instead because I indeed prefer not to miss any values.
@Intaris
No, I'm not opening and closing the file. A snapshot of the code in question is below:
Either way I'll try to throttle the loops properly now and get back with the results.
Message 6 of 11
(5,852 Views)
Maybe you could try setting the buffer size for the TDMS write (allowing the driver to cache information for you, reducing the number of individual write operations).
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/setting_tdms_buffersize/
Shane
Message 7 of 11
(5,836 Views)
Thank you for your help guys. I've marked it as solved since ultimately the issue was my misunderstanding of the timeout function.
Message 8 of 11
(5,797 Views)
Cool.
Message 9 of 11
(5,783 Views)
It seems like I'm still not where I want to be. When I call the shared variable read node, it returns the first value in the buffer as it should. Instead, I want to read out the entire buffer in one go. How can I do this most efficiently?
I understand that a queue might be better for this since I can flush the queue when I want, but I have problems with the queue data type. If I try to flush a queue that has an 1D array of double as data type, it returns a 1D array of a 1 element cluster containing the 1D array of double. I can't for the life of me figure out how to turn that back into the 1D array of double I am after. Also my code gets stuck trying to use a queue but that is for me to figure out later.
Is there a way to avoid using a queue here? How do I read say 100 values from a shared variable FIFO before I dump it to disk?
Message 10 of 11
(5,780 Views)
