TERMOMETER, DATA READING, DATA PRESENTATION
Hi, im new in Labview and i have problems with preparing a program, can somebody help, maybe have some suggestions?
The program needs to have:
- preparation of an application that allows you to read measurement data from a two-channel thermometer
- possibility of conducting continuous measurements for a set time (displaying currently measured values in a graphic form)
- possibility to save measured values to an external file
- display of the highest, lowest, difference in measured values on two channels and the average value of measurements
(1,752 Views)
What have you tried for this ?
Have you made a first VI to test something ?
There is a lot of training course and examples available (I'm sure somebody will drop a good link to training courses later).
(1,737 Views)
Hi krawczykm,
Well: which problems do you have? Anything specific apart from "new to LabVIEW"?
A good starting point is found in the header of the LabVIEW board, where NI mentions several training resources!
(1,716 Views)
All of these are definitely possible in LabVIEW.
To get started with the first item, I would recommend this tutorial - https://labviewwiki.org/wiki/VIWeek_2020/Proper_way_to_communicate_over_serial
And you need to share a lot more information on your skillset, hardware and software at hand.
Santhosh
Soliton Technologies
(1,657 Views)
