error message
i'm working  with tracking with image optical flow. I have 3000 images that are analysed, and I work with an hard disk of 500 GB and moreover the memory of my PC is about 113 GB. I receved an error message that tell me that there aren't enought memory to continue. how can I do?
Message 1 of 25
(4,238 Views)
Well you need to provide a lot more details.  Best would be to post your actual code back-saved to an earlier version (probably LV2018 or so) as many people don't use the most recent versions.  At the very least, screenshots of block diagrams and the like.
With a description that vague best guess is that you're not freeing references after being done with them, or expanding an array to be too large.
Message 2 of 25
(4,206 Views)
Hi ludovica,
@ludovica99 wrote:
 how can I do?
What about attaching some code?
What about clarifying which LabVIEW version you use?
Is that 113GB RAM or HDD?
Message 3 of 25
(4,205 Views)
113 GB on Windows(C). the version of Labview is the one of 2022
Message 4 of 25
(4,197 Views)
that is the error message 
Message 5 of 25
(4,196 Views)
Hi ludovica,
why do you relate HDD space with RAM requirements?
You still don't tell which exact LabVIEW version you use (bitness, modules, base/full/pro, ...)
You still don't attach code ..
Message 6 of 25
(4,181 Views)
i don't know how verify the RAM requirements.. can you tell me? i use lab view 2022 32bit , maybe the base version.
oh sorry... i don't know how share the labview program
Message 7 of 25
(4,160 Views)
sorry... i have verify, i have about 8 GB of RAM
Message 8 of 25
(4,154 Views)
Hi ludovica,
this is not a LabVIEW program. It rather looks like MATLAB...
Message 9 of 25
(4,148 Views)
Message 10 of 25
(4,142 Views)
