TRANSFORM A TEXT FROM TXT FILE
My problem is that I have a txt file and I have to transform it. This txt file has numbers separated by commas in only line, I don't know how many numbers It has. I want change the commas for a carriage return (\n). What do I do? I help that urgent, anybody could help me please?
Message 1 of 13
(3,678 Views)
Here's a VI that could be interesting for what you want to do.
Hope this helps !
Julien
Message 2 of 13
(3,678 Views)
same VI for LV6.1
Julien
Message 3 of 13
(3,678 Views)
Something like this...
Wiebe.
"IMMA" wrote in message
news:50650000000800000032CE0000-1079395200000@exchange.ni.com...
> please?
[Attachment File convert.vi, see below]
Message 4 of 13
(3,678 Views)
Oops, replace the "'" with a ",".
"Wiebe@CARYA" wrote in message
news:407fb03b@newsgroups....
> Hi,
> Regards,
> Wiebe.
> > please?
Message 5 of 13
(3,678 Views)
Please, can you send another time your vi? I can't charge it with my labview, my computer said: there was an error.
Thanks a lot.
IMMA
Message 6 of 13
(3,678 Views)
Please, can you send another time your vi? I can't charge it with my labview, my computer said: there was an error. Perphaps the problem is that my labview is 5.1 version.
Thanks a lot.
IMMA"
Message 7 of 13
(3,678 Views)
Thanks a lot.
IMMA"
Message 8 of 13
(3,678 Views)
Have you tried the Read From Spreadsheet File function (File I/O palette)? Use a , as the delimter and it should work just fine for your file. If it doesn't, could you post the text file you're trying to read?
Message 9 of 13
(3,678 Views)
Here's a picture of the VI I sent earlier
If your txt file is made of more than 1 line then it still works but concatenate all the lines to the new txt file.
Hope this helps !
Julien
Message 10 of 13
(3,530 Views)
