TTi CPX400
Make sure you see your device in MAX under Devices and Interfaces as a COM* device using USB or under Network Device;
Instument driver:
https://www.aimtti.com/support
IVI driver
https://www.aimtti.com/resources/cpx-series-power-supplies-ivi-driver-v140
Support Software Required for IVI driver  [from: https://www.ivifoundation.org/registered_drivers/open_file.ashx?ID=3279 ]:
- IVI Compliance Package,
- VISA,
- IVI Shared Components (https://www.ivifoundation.org/shared_components/Default.aspx)
For me it was enough to use CPX400 in two ways: with instrument driver VIs in LabVIEW and also as a IVI DCPwr.
CPX400 under IVI Drives Session was visible after IVI driver installation and PC restart.
Message 11 of 13
(1,126 Views)
As previously mentioned, installing the drivers from this website doesn't seem to work.
For anyone who needs basic functionality for this PSU, here is a simple example (attached) to interact with it based on the documentation at
CPX400D+DP_Instruction_Manual_EN_48511-1480_14.pdf
Message 12 of 13
(176 Views)
I ran the LabVIEW install of those TTI IVI drivers from the website and used them along with the CPX400.llb library mentioned in this post: Solved: Missing dll files - NI Community
The single CPX400.llb library was placed in the instrument VI folder for LabVIEW.
Also, I had to copy and register the CPX400DP_32.dll to the Windows System32 folder.
My program now works for the 32-bit version of LabVIEW 2025.
Message 13 of 13
(137 Views)
