TURN ON ARRAY OF BUTTONS
It works perfect!! Thank you so much for explaining me everything! I am very grateful with all your help!
Best regards!
Message 11 of 14
(947 Views)
Hola!
Como puedo hacer para que cuando meta un string cada caracter del string me active su correspondiente boton en un array de booleanos?
Gracias!
Message 12 of 14
(952 Views)
Look into the event structure.
Either catch the key down and key repeat events, or use the value change event (set the string to "update while typing").
Message 13 of 14
(939 Views)
I think this merged post is actually a different question...
Message 14 of 14
(934 Views)
