TURN ON DIGITAL OUT
If te temperature goes below for two hrs the digital out should be on, and next two hours wait there for the next cycle.
I am running switch and need to activated every 4 hrs. the chamber is running seperately and the heater needs to be turned on if the temperature is below zero.
Thanks for advise, I will take your suggestion and modify the vi.
Thanks again.
Jey
Message 11 of 11
(401 Views)
