Tab Control Bug
http://lavag.org/topic/11081-tab-control-bug/
Hi
I guess many of you have encountered this issue with the tab control.
Is this a bug or something everybody knows about and always just manage to live with it.
The problem is that the Tab Control don’t always changes Tab when you programmatically changes is using a local variable, if you at the same time updates a control or indicator using the property node which is located on any of the tabs.
Cheers,
Mikael
(3,653 Views)
in selection number to case structure you have it going to string value property node instead of string 2 value property node I think that may be your issue
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,645 Views)
I believe the problem is that there is a race condition for write to string property and the code to change tab value.  Make a data dependency between the two section of code (such as with error clustor) or use a sequence shall make it work.
(3,638 Views)
please try the attached.
(3,637 Views)
