timer
Hi there,
I am Vijay, I am quite new to LABVIEW and would appreciate the help from u.
I am currently designing the solenoid valve control for fuelcells. I  have a few problem when setting up the timer for the valves. The agenda is the user sets the on timer and the off timer for the valve. I am using a case structure where the valve is connected. And when having two timer values for the same valve i have some problem. also I even get a problem when connecting the single timer(ON).
Could someone help me on how to proceed furthur on this.
Vijay
(3,626 Views)
What is your problem? You say you have a problem, but you don't give us any details about it.
Please post whatever VI you have so we can look at it, and tell us how it isn't working right for you.
(3,621 Views)
Well, you can use the 'Elapsed Time' express VI.
Or you can use a little math and the Current Time ms VI.
What exactly are you stuck on?
Cory K
(3,606 Views)
Vijay I think this will be usefull for you. I used this code in my old project need to optimize for your need.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,604 Views)
Thanks a lot ppl... Its working fine now. a ver special thanks to Baji Smiley Happy
Vijay
(3,566 Views)
