Tab control Output value to be display in other pages
Hi guys
I hava a VI using a tab control with multiple pages. The 1st page will have some calculation and give an ouput ,x.
Then i will proceed to the 2nd page to perform other action, however i need the input automatically from what i have acquired in the first page, which is x.
My problem is that i could not link up this output from the 1st page and send it to the 2nd page.
I thought it should be a reliatively simple but i am stuck in this. Please help me
Cheers
PX
(3,331 Views)
Hi pengxin,
do you mean, you want to see x on all pages? If yes, then don't palce x inside the tabcontrol. Just add it to the front panel and move it with the arrow keys over the tab control.
Mike
Message Edited by MikeS81 on 03-25-2010 02:18 PM
(3,319 Views)
Hi
This x value need to be calculated within the first page. Bcos my first page will be doing data acquistion and calculation.
Then this x value will have to carried to 2nd page then i will run the functions in 2nd page.
Cheers
PX
(3,313 Views)
HI pengxin,
what do you mean? The calculation will be made in the blockdiagram, this is independent from where you have placed the control, except a cluster.
Mike
Message Edited by MikeS81 on 03-25-2010 03:10 PM
(3,311 Views)
Hi Mike
I think i got it i just have to make a feedback node and the tunnel with "Use default If Unwired"
Thank you for your effort help me.
Cheer
PX
(3,295 Views)
Hi PX,
can you please post what you have? I like to see it, because i am not sure what you have meant.
Mike
(3,287 Views)
Wire x to local variable of control in 2nd page.
(3,270 Views)
