put file-error access denied
i want to put test.txt into ftp file, but the error...my error display 'access is denied'...what's my problem???
(4,034 Views)
Hi snta1806,
are you sure that the "anonymous" account exists?
Mike
(4,025 Views)
yes,,because anonymous is default account. why my simple coding is error?...i'm using internet explorer to open ftp://192.168.2.65 and the result is ok
(4,015 Views)
Try:
  • specifying a correct path for the remote address. Something like '/path/to/file.ext' (without the quotes)
  • using passive mode (set the active flag to False)
(3,999 Views)
can't... always error 'access is denied'...i try using an example in NI, the problem still display 'access is denied'
(3,988 Views)
1. Log into your stp using command line, and find out which remote path that you can put a file.
2. Put path in #1 to remote path of ftp put file.vi. For example: /incoming of ftp.ni.com. If it's root path, just put /
(3,980 Views)
