Showing results forĀ
Search instead forĀ
Did you mean:Ā
Tab control property node
Hi, please explain the difference between two operations explained below. For reference I have attached tow images here.
Theoretically, as per help page in labview, When i set ' allow multi colors property ' to true, i can change the colors of the page in tab control. But here, program runs in a reverse way. When I set that property to false and run a program, tab control object in front panel will change to the color i have given(First image with bule color tab control). When set to true and run a program, it gets defualt color( second image, default tab control). I don't know how it happens, help me. Thanks in advanceSmiley Happy
Best Regards,
Dhans šŸ˜‰
Kudos are welcome šŸ˜‰
Aspirant Labview Programmer (Labview 14) šŸ˜‰
(6,946 Views)
Hello dhans,
In tab controller user can add number of tabs. If you want to change the FG color of all tabs as a same color then the multicolor property node is used and it should be set as FALSE.
Whenever you want to change the single tab FG color then you should make multicolor property as TRUE.
Attached snap for both... Smiley Happy
(6,936 Views)
Hi, thanks for reply. But I did run program as u said. But no change is happened at front panel side. It still remains as second image attached in above. default tab control only appears. Is there anything in program i need to change?
Best Regards,
Dhans šŸ˜‰
(6,931 Views)
Attach VI Instead of Image,
Make sure you are aware of execution of property node (Top Down), if you attach the code which you have tried it will helpful  for others to run and debug
Palanivel Thiruvenkadam | ą®Ŗą®“ą®©ą®æą®µąÆ‡ą®²ąÆ ą®¤ą®æą®°ąÆą®µąÆ†ą®™ąÆą®•ą®Ÿą®®ąÆ
LabVIEWā„¢ Champion |Certified LabVIEWā„¢ Architect |Certified TestStand Developer
(6,925 Views)
Accepted by topic author dhans
You should get the Tab Page reference and change the color individually if you want.
-Set the Allow Multiple Colors to TRUE: https://zone.ni.com/reference/en-XX/help/371361J-01/lvprop/tabctrl_allow_multi_clrs/
-Get Each Page reference:https://zone.ni.com/reference/en-XX/help/371361J-01/lvprop/pagesel_pgs/
-Then choose color as you want : https://zone.ni.com/reference/en-XX/help/371361J-01/lvprop/page_clrsfg_clr/
uday
(6,921 Views)
Thanks a lot buddy
Best Regards,
Dhans šŸ˜‰
(6,892 Views)
Hi everyone,
I have a .vi in which long ago I experienced some of the TAB control properties.
I am attaching hoping helpful
(6,876 Views)
