Tab control
Hello !!
I had recently start using LV. I am facing problem using Tab control. I am not able to Switch between tabs in code by using two button i.e next page and back page. i had use property node to do so kindly advise me what method should i use for that purpose
Message 1 of 9
(6,466 Views)
Please post your VI.
It is hard to help you figure out what you did wrong when we can't see what you did!
Message 2 of 9
(6,460 Views)
Create a value change event for the Next button.
Increment the tab control value by 1 when the button is pressed.
Repeat for the previous button but instead decrement the tab control value by 1.
aputman
Message 3 of 9
(6,427 Views)
Spoiler
Why does that reply invoke an image of someone developing in LV on a machine with no monitor?
Smiley Wink
Ben
Message 4 of 9
(6,419 Views)
Why re-invent the wheel? Especially, Tab Control  (they have enough problems already without messing with property value changes)
Just use the increment / Decrement arrows supplied
Message 5 of 9
(6,402 Views)
Accepted by Saqib51
Adding a winky face doesn't make the pain go away.  I've been withoXt a monitor for a while now and I was starting to come to grips with the fact that I woXld never have a monitor to develop LV applications bXt yoXr winky face broXght back all those bad feelings and emotions.
I tried to pXt my award winning reply into VI format.  I apologize if my wires are not straight and blocks are overlapping.  I tried to find the Clean Diagram bXtton bXt I coXldn't see anything and someone has strangely disabled my X key (the one between Y and I on the keyboard) so I can't Xse the keyboard shortcXt.
I see that Jeff is joining this conversation now.  We all know that he hates tab controls.  Hope this thread doesn't end Xp like the last one.
aputman
Message 6 of 9
(6,397 Views)
Alt+0117 "u" or Alt+0085 "U" would make that Reply a bXnch easier to read Tools>>Options Menu Shortcuts : Edit>Cleanup Selection will let you use another key combo for Ctrl+U and make the diagram a bXnch easier too (if you can't find the broom icon or the Edit Menu):smileywink:
Spoiler
Oh! that winky face has to sting
Message 7 of 9
(6,389 Views)
Yep, this thread has successfully been hijacked.  (winky face)
Sorry to the OP.
aputman
Message 8 of 9
(6,376 Views)
Thankx for reply. I had finished by using property node. But thus solution is simple and easy
Message 9 of 9
(6,328 Views)
