Table Control with Drop Down Menu in LabVIEW
Hi All,
Anybody know how to create a cell with a drop down menu in a table control?  There is one example below.  I've not tried to build it yet, but I have my doubt because it that you cannot put a ring control on top of a table control, even while manipulating its position with properties.  Anybody know more about this?  If I build this exactly as shown, are rings suddenly able to be on top of tables?
http://www.labviewing.com/table-with-drop-down-menu-in-labview/
(7,207 Views)
Accepted by andy_3141593
Why not? You can put any control on top of any other control. You may need to change their Z-order (see the Reorder drop down in the toolbar).
Paolo
(7,202 Views)
Ctrl+Shift+K once with the control selected, or
Ctrl+Shift+J once with the table selected.
Or
Ctrl+K until on front with the control selected, or
Ctrl+J until behind the control once with the table selected.
This simply invokes the menu items Paola mentioned:
(7,178 Views)
Try this
(7,155 Views)
Hi All,
Thank you.  I wasn't aware of the "Z-Order".  That did it.
Andy
(7,123 Views)
Kudo for marking the solutions!
(7,104 Views)
