Table Indicator Custom Appearance resets everytime
I have a table indicator that gets updated with values periodically.
I have disabled everything except vertical scroll bar, vertical/horizontal lines, autosize row size and smooth scrolling.
I went into advanced -> customize -> customize mode and increased the size of the vertical scrollbar and button for ease of use. It seems to work when i apply the changes, but after saving everything and the project, everytime I reopen the project and open the main vi, the scroll bar is reverted back to the original appearance.
I tried saving the edit as a control and as a type def, but the changes only show up when i open the saved control/type def and not on my main vi front panel.
(1,461 Views)
*By table I meant 2d array of strings indicator
(1,411 Views)
Try adding these lines to labview.ini:
AutosizeScrollbar=False
autoResizeScrollbars=false
(1,394 Views)
