Update enum control with typedef
I'm trying to update enum control , with enum TypeDef.
But there is a conflict.
Is it possible at all to connect this two elements?
Is there any solution?
Best regards.
(1,750 Views)
You need to replace your control with the type def as well.
(1,719 Views)
The control and constant are incompatible: The constant is an enum with 2 elements and the control is an enum with no elements.
Just replace the control with an instance of the typedef (right-click on the control, select "Replace -> Select a Control ..." then browse to the typedef file).
(1,716 Views)
