Table keep updating
Hi guys i need help on this VI.
I am going to write the data in hex form ,convert to number, and display in table form/list form.
Now my table continuing repeat the same result and i want it to show the result only when i key in the hex and press enter. but it simply dont do this.
And it keep showing the same result even i key in many data.why it behave like that ? I already put it into a while loop .
Thanks in advance.
(2,851 Views)
Attach your code!  Without seeing what you're doing, how can we help you?
(2,847 Views)
Sorry i make my question too confusing.
i want to convert my a bunch of hex data into decimal and show in a table.
But now it can only convert the first 2 digits and ignored the rest.
i tried quite a few method but none of them works.
My hex data may not be in a nice format thats why i need to extract out.
I appreaciate your helping.
Cheers.
(2,813 Views)
I'd start with something like this, then make it more complicated if you need to strip out non-hex characters first.
(2,798 Views)
