Tabs controls frozen
I have tab control in my vi. I used the tool palette to change the background and saved the vi. After I opened it all the tabs are frozen
wherever I click it shows the blue dotted line across the whole tab panel. Does not show the individual tab. How can I make all tabs active again. This is so weird.
Girish
(1,285 Views)
Accepted by girish53
Are you sure that after you used the tools palette, you changed back to the auto-tool?  If you were only getting the "pointer" tool instead of the "finger" tool, that might do what you described.
You could also do a quick check of the "Reorder" menu to be sure you didn't lock the control:
(If it was selected but locked, then "Unlock" would be a selectable option)
(1,269 Views)
