Tabs
Helo.. I'm using multiple pages in my VI. The problem is,i have created a text in first page,n it is displaying in other pages too. If i delete the text in other page,even the 1st page text is also erasing. how to avoid it..? other pages should be empty,so that i can use it for other functions.
Thank you,
sushmith
(4,468 Views)
Hi sks,
          Please post your VI.
Thanks as kudos only:)
(4,467 Views)
How you are creating the text. Are you typing the text in the front panel outside the Tab and dragging it into the Tab? If yes try to copy and paste the text. It would be good if you post your code.
(4,462 Views)
This is the VI wat i'm doing.
(4,459 Views)
I have typed text on boolean LED. i did that on page 1.
(4,455 Views)
Accepted by sks1990
No its not the right way. You have to use the boolean text of that LED which you can make it visible by Right Click >> Visible Items >> Boolean Text.
(4,444 Views)
Oh!!Very simple..!! Thank you so much...:-)
(4,437 Views)
