Taking and plotting standard deviation
I have been given a signal to analyze, and my first step is to come up with a method of evaluating the effectiveness of the selected filter. My train of thought was to take the derivative of the filtered signal (this is what we want to plot since we are reading some engine data), and then take the standard deviation of the noise from the filtered signal derivative and plot them against each other. My thinking is that the plot would show a smaller std. dev. as the effectiveness of the filter gets better. To do this, I have the following code, but it seems to only be plotting single values, rather than the whole array.
Any help would be appreciated.
Thanks!
(1,257 Views)
A picture is not code. (we cannot run it, we cannot see what's outside the visible area or what's in the other cases)
Please attach your VI and some typical data. (use "save for previous", 2020 or below if you use a recent version)
Most of the code looks very wrong, e.g. the initialize array and an non-indexing output tunnel that only returns an array with all the same element from the last iteration.
(1,233 Views)
I was provided the code.
The only part I have coded is the portion circled in red, and that is after several hours of tinkering with it.
(1,197 Views)
Maybe all you need is remove the array subset and that FOR loop (assuming you want a horizontal line at the level of the standard deviation).
(You did not use "save for previous", so I cannot look at your VI)
(1,184 Views)
