Tangent for an exponential function
I have data as shown below.
I would like to use Labview to get the tangent in the point where Y =2.
Message 1 of 13
(8,430 Views)
Accepted by Michael.Koppelgaard
  1. You have got the exponential function coefficients, so you got the equation: y = 9.8659 * exp(-1.27*x).
  2. Using the above function, first calculate the x value at the required y-position: (ln(9.8659)-ln(2))/1.27 = 1.25664...
  3. So you want to find the tangent at point (X_0; Y_0) = (2; 1.25664).
  4. Take the first derivative of the function, and calculate its value at "X_0". This gives you the slope of the tangent line: "m".
  5. Use the line equation: Y - Y_0 = m* (X - X_0)
edit: i made a mistake, just swap the X_0 and Y_0 !
EDIT2: so to clarify:
  1. find the tangent at point (X_0; Y_0) = (1.25664 ; 2)
  2. The first derivative of the function is: y' = (9.8659/-1.27) * exp ( - 1.27 * x )
  3. Calculate the first derivative's value at X_0 --> you get the slope "m", m = - 1.5748
  4. Using the line equation, we get the tangent: y = -1.5748*x + 3.9789
Using LabVIEW, you can get the coefficients, and also can get the coefficients for the derivative. After that just simple math to find tangent at a certain point.
Message 2 of 13
(8,389 Views)
Or you try one of the Derivate functions and they should give you a good approximation, if it's only the answer you're after.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 13
(8,384 Views)
Actually, the only data I’m interested in, is the slope of the tangent in this point.
In order to get the fit, I used exponential fit, hoping I would get the expression of the curve as I did it in the in excel (image).
The derivation function you talked about, where do I find it, and how to use it?
Message 4 of 13
(8,365 Views)
Derivative x(t) under mathematics ==> Integration & differentiation.
I haven't tried it, but the help and the linked example (in the help) looks good.
/Y
Qestit Systems
Message 5 of 13
(8,359 Views)
The exponential fit outputs the "amplitude" and "damping" (and "offset", but you currently force the offset to be zero). These are the two parameters that define the best fit and you can analytically calculate the derivative instantly for any desired X. This is the correct way.
(Doing numerical methods, such as the mentioned derivative function will not give you anything accurate)
Message 6 of 13
(8,338 Views)
Hi Blokk
Thank you for your very fine explanation
Using your calculation of the tangent seems to give at wrong result ?
Are you sure the derivative is correct ?
I get the derivative: a*b*exp(b*x). Don’t know if that correct?
Message 7 of 13
(8,317 Views)
That's what wolfram alpha says. 😉
Message 8 of 13
(8,307 Views)
That is correct, the division was my mistake. When you derivate this, you need to multiply with the derivative of the internal function.
Message 9 of 13
(8,304 Views)
Message 10 of 13
(8,302 Views)
