Tektronix MSO5X Scope
Hey,
I have a Tektronix MSO5X Series, that I want to autoscale the vertical axis. Now, I'm using autoset -> read the vartical gain-> undo autoset -> set the vetical gain, but its a long proccess.
thanks, Erez
(2,558 Views)
Hi Erez,
and what is the problem? Where are you stuck?
I want to … but its a long proccess.
So you already got a solution?
And how is all this related to LabVIEW?
(2,528 Views)
Hi GerdW
Im Using labview to control the scope. I was hoping there is a better way to autoscale (the one I'm using is time consuming).
Best, Erez
(2,509 Views)
Hi Erez,
I guess the autoscale feature is described in the manual of your scope.
Did you read it?
(2,503 Views)
