Tektronix TBS 1102B
Hello everyone,
I am using Tektronix TBS 1102B Oscilloscope. It has a 100 Mhz bandwidth and a sampling ratio of 2 Gs/s.
I want to capture signal for the first 150mS when I press start on my front panel in labview 2017. I tried using the example vi's that came with the library. But did not succeed. Can anyone help?
Thanks.
(3,066 Views)
Hi rk,
What have you tried?
Whare are you stuck?
What means "first 150 milli Siemens"?
In case you want to read for a certain amount of time you should set the required sample rate and then read the needed number of samples:
num_of_samples [Samples] := samplerate [Samples/s] * time [s]
(3,062 Views)
I tried editing the examples, but I do not seem to find a solution to acquire signal only for first 150 milli 'seconds'.
(3,058 Views)
Anyone?
(2,882 Views)
Hi rk_t,
So you can read samples, but you get more than you need?
Why don't you use ArraySubset to keep only the first 150ms of your signal?
(2,880 Views)
