Tektronix TDS3034B
I'm attempting to access my Tektronix TDS3034B through its ethernet port using VISA calls.  The TDS3034B user manual says that I must use the Tektronix VISA in order to access the device, however, I am able to access it  using NI-VISA only (I haven't installed Tektronix VISA).  But, I can't see the device in the VISA Interactive control window.  Do need to use NI-VISA to access this device, or should I install Tek-VISA and use it?  And, if I use Tek-VISA, is there any use for NI-VISA?
Brent
(3,226 Views)
You should be able to use NI-VISA in conjunction with the intrument drivers which you can download here:
http://sine.ni.com/idnetwork/main/p/sn/n25:TV.tektronix?q=Tektronix+TDS+3034&x=13&y=13
If you are using ethernet to access the device, you'll probably need its IP address.  The VISA resource name field will resemble something like this "TCPIP::192.168.1.12::INSTR".
Message Edited by Support on 01-02-2007 01:35 PM
(3,217 Views)
