Telnet Error code 56 with Telnet Line Client Example?
Using Labview 8.5, XP, Telnet Line Client, I get the following error 56, TCP Read in Telnet Buffered Read.vi->Telnet Read.vi:3->Telnet Line Client.vi.
I looked up this error which looks to be a Networking error:  56 The network operation exceeded the user-specified or system time limit.
The data does seem to return properly but this has been an ongoing issue with previous Telnet clients we are using.
(4,185 Views)
Almost Duplicate Post.  See here.
(4,170 Views)
Hi ShotSimon,
You may want to refer to this KB. The Telnet Listen.vi uses the TCP Listen.vi. I hope that helps!
(4,160 Views)
