how do I get the statistics express to read more than 10 segments when reading from a .lvm
I have tried 2 ways of doing this.  I had an for loop set up with a "Read labVIEW Measurement FIle" then a xy chart to plot the 2 measurements vs. each other.  The chart works and will plot everything great but the "Statistics" express will only take 10 samples at a time and will keep redoing the statistics for each subsequent segment of 10 samples.  I tried to change this to a while loop but then the same thing happens with the stats and the xy chart does not graph.  How do I get the stats calculate for the entire file?
(2,440 Views)
Richard,
Thank you for contacting National Instruments.  I think I understand what you are looking to do here, but it might be easiest for myself and others to help you more specifically if you post a screenshot of your code, or your actual VI.  However, I looked into trying to achieve something similar, and used a loop structure to bring the information in from a file.  Then, outside the loop, I used the Statistics Express VI from the Mathematics palette to obtain some statistical values.  What type of statistics are you looking to receive from this program?
Jason W.
(2,408 Views)
