Telnet with Labview
Hey Everyone,
Thanks in advance.
I am trying to connect to a CAN-Ethernet gateway using Labview through Telnet. Basically, I want to change some settings on it while my main VI is running the tests.
My main program gets the data from the gateway without any problems. I am using TCP/IP to get the data from the gateway in my program. Thats why I prefer to use Telnet to make changes to settings  on the gateway.
I am Telnet support has been discontinued in Labview, but was wondering if there is a work around, Any sample snippet or example would be helpful.
(5,319 Views)
Have you considered using a .NET implementation of Telnet to see if that does what you want?
This is the first result on Google, not sure if it's actually good or not as I haven't used it myself.
(5,310 Views)
Hi Kyle,
I havent used .NET ever before. Does Labview have support for .Net?
(5,306 Views)
Yes
Here's a page with a bunch of links to help.  Start with the "Examples" section and go from there.
(5,300 Views)
As I state in another thread, you can just use the standard TCP functions to communicate with a Telnet interface.  This works just fine as long as the option characters are not used.
(5,276 Views)
As suggested you can use a standard TCP connection rather than telnet.
Does the gateway host a web server for changing settings via a browser? If so you could embed a web browser and allow the user to change the settings here.
If it needs to be programmatic, you can use HTTP GET and POST requests to change the settings too. I have done this before on an ethernet/can gateway without any problem. Obviously it depends on the make and model, and what it actually supports.
Deceased
(5,228 Views)
Thanks Crossrulz,
I was able to communicate with it using TCP functions. Really appreciate your help
(5,196 Views)
