Temperature acquisition on USB-Temp
I'm using a Measurement Computing USB-Temp in order to acquire temperature with several sensors. I've made the attached program for two sensors. The problem is : I have to add a waveform for every sensor I have. So the program will rapidly become unreadable if I want seven or eight sensors.
Do you know a way to correct it ? Maybe with arrays...
Sorry for bad english
(3,623 Views)
Accepted by topic author simchoots
Yes - instead of having a single waveform on your shift register, change that to an array of waveforms. You can then have your data acquisition in a For loop for the number of sensors you have.
Here's a very simple of example of how you can modify your program:
Also, be aware that because you are continuously building a waveform, if you run your program for a long time you will eventually run out of memory. You might want to consider looking at the Producer/Consumer architecture so that your logging happens while the data is being acquired, instead of just at the end (it also means you have data if your computer crashes 🙂 ).
(blog)
(3,615 Views)
Thank you for your answer ! This is what I needed.
What do you mean by "a long time" ? Is it an hour or a day 🙂 ?
What if I create a conditional structure in the while loop that save the data when the user press a button ? It would avoid the loss of data.
Thanks again
(3,609 Views)
Depends on how much data you are acquiring and how quickly. Run your program and look at it's memory usage in Task Manager. It will grow over time.
Look at the producer/consumer examples in LabVIEW (or google 'producer/consumer LabVIEW') and you will find examples of how you can use a queue to send your data to another loop for logging.
(blog)
(3,604 Views)
Okay thanks !
(3,586 Views)
