serial communication
i am trying to view the data of a bluetooth module on waveform chart in three axis through serial communication but reading of all the three axis is coming on one graph and the other two are empty. please help me out
Message 1 of 8
(4,384 Views)
Does your data have a termination character e.g. a newline (your configure serial port says you are)? You should stop using 'bytes at port' and instead put the number of bytes to something large (longer than the expected string) and then the read will return one line of data.
Using bytes at port might return fewer bytes than a full line of data.
(blog)
Message 2 of 8
(4,376 Views)
i gave no of bytes as 200, then 2000 and even 30,000 but nothing is happening. its still the same
Message 3 of 8
(4,371 Views)
Well you failed to include any information about the actual data you are receiving - what do the strings look like?
From your code, you're expecting "0.123,0.5123,12\n" - is that what you're getting?
(blog)
Message 4 of 8
(4,358 Views)
data that is received is data value of the motion of the module in all the 3 directions
Message 5 of 8
(4,352 Views)
We already knew that.  What exactly is the format of the data you are reading?
Message 6 of 8
(4,346 Views)
floating point data is being read
Message 7 of 8
(4,339 Views)
Hi areshi,
with VISA you receive just strings (or U8 arrays) - no floating point numbers here.
Please provide the full description of the data format you want to receive/convert!
Message 8 of 8
(4,322 Views)
