Temperature and Voltage read by Keihtley 2182A
Hi I have a problem with nanovoltmeter 2182a , I'm trying to read tension on channel 1 and temperature on channel 2 (I have a thermocouple), I'm using Labview and Visa
well the program works fine, but I can't read every second , the minimal is 1060 miliseconds , because if I do it faster
an error is showed in the screen error -363
this is what I send
: sens: func 'temp'
: SENS: CHAN 2
: SENS: DATA:fresh?
: sens: func 'VOLT'
: SENS: CHAN 1
: SENS: DATA:FRESH?
thanks
Message 11 of 12
(518 Views)
Hi rodrigoromo,
Can you send a screenshot of the error you are seeing. I really haven't been able to find much on it.
Ryan
Applications Engineer
Message 12 of 12
(504 Views)
