Test sequence
Hi everyone,
I am doing a test setup for my PCB.
My project  is to make a Test sequence in Labview to test,measure and perform calculations from the PCB peripherals.
I wanna make it like "HIT" start and then the test sequence begins one by one . I cant afford Teststand so wanna make it labview.
Can you suggest me any design pattern for test sequence more faster?
Boldness has genius, power and magic in it!'
(3,966 Views)
Accepted by MaveenD
Hi Maveen,
for such less information I would suggest: try a state machine approach!
(3,965 Views)
Thanks for the reply.Can you tell suggest me some samples examples with test programs .
I couldn find it.
(3,957 Views)
Help>Find Examples>Industry Applications>Test Sequencer or File>New...>From Template>Design Patterns.
(3,943 Views)
