Text input
I have text box that is continuosly receiving serial data from an instrument.
As soon as data populate the screen they start dissapiering at the botom
of the text box. I have scroll bar so when I stop the VI, I can scrol to see
this data.
 I need to change this, so while the VI is running and data coming I need to see
newest data and have old data dissapiering at the top of the text box.
How to do this, what I need to change or add?
Sead
(3,829 Views)
Did you try to search the forums?  I did a search on "text box scroll position".  http://forums.ni.com/ni/search?board_id=170&submitted=true&q=text+box+scroll+position
Here is one link that came up.
(3,822 Views)
Hi Sead,
use the Text.ScrollPos property of your string indicator and connect the string size to it.
Mike
(3,821 Views)
Thank you for sugestion.
I did it with Text Scroll position and it works. Only when I had value 0
I could not scroll back up when VI stop running so I changed the value to
very large number 10000. That did the trick. Now I have new data continuosly
on the screen and I can scroll back to se the old data when VI is stopped.
(3,802 Views)
