The 3D picture indicator does not appear in the web publishing tool
I am using LabVIEW 2012 professional 32-bit. There is a 3D picture indicator on the front panel of my VI which shows a robot. I used the web publishing tool and trying to see the front panel via explorer. Unfortunately the 3D indicator does not show anything. How can I solve that?
(2,623 Views)
what viewing option are you using in the web publishing tool? Embedded, Snapshot, or Moniter? These viewing options often provide difficulties for indicators and controls on the web page
Aaron L.
(2,584 Views)
Thanks a lot AaronTheAE.
Actually, I tested all these types (i.e. Embedded, Snapshot and Moniter) but the 3D indicator did not show anything. An important thing that I forgot to mention is that I used the STL file format to illustrate my robot. Do you think this is the problem? Is there any solution?
Thanks again
(2,561 Views)
