robotics simulator and uav
hello everyone
is what I use robotic simulator to simulate a UAV model?
if there is please the complete method or example
(3,199 Views)
Hi kahled24,
I found this NI Community post that may help you with your application.
If this is not what you are asking, could you please clarify your question?
Briana P.
Licensing
Sr SW Engineering Manager | NI R&D
ni.com/support
(3,139 Views)
my question is can I import a 3D model of UAV .dae (COLLADA file) as is here http://www.ni.com/tutorial/14780/en/
and simulate. because I no example predefined except arms and mobile robot
(3,125 Views)
Have you tried this tutorial with the COLLADA file? If so are you seeing an error? Are you having issues with the import or with the simulation?
Take a look at this links:
http://www.ni.com/white-paper/14133/en/
https://forums.ni.com/t5/LabVIEW-Robotics-Documents/Import-and-Simplify-CAD-models-in-LV-Robotics-20...
Briana P.
Licensing
ni.com/support
(3,101 Views)
I work with solidworks, I can just save my file .wrl.
in this link http://www.ni.com/white-paper/14133/en/           I find that I can import this file type.
but when I import my file it displays this error
(3,082 Views)
