The NI LabVIEW plugin has crashed
Hi, I am very worried, i am probing my application Labview with Web Publishing Tool, it includes the following:
I have to access to the application from the client with Opensuse 12 that i have installed.
I installed the plugin (RPM) correctly http://joule.ni.com/nidu/cds/view/p/id/2538/lang/es. (I can see the installed plugins in firefox browser through URL about:plugins) and this is ok.
I could not find the folder .mozilla\plugins and usr\lib\firefox\plugins so i had to created them. And i put the LV2011NPlugin.so file there as the recomendations say http://digital.ni.com/public.nsf/allkb/151BE12C055F57CE86257043006CB4B3?OpenDocument#Linux .
When i acces to the application i get this:
Please, Please, Somebody help me. I will really appreciate it.
(4,504 Views)
Please, I need some help.
(4,475 Views)
Hello Tolima,
which version of Labview are you using to create a Remote Front Panel? You should use this version of LV Run-time Engine (2011) to run Remote Front Panels that were built with LabVIEW 2011. So check your versions.
Ricardo Ramos
Account Manager
+5511989658513 | ni.com
(4,437 Views)
Hi rramos, thanks for replying. I'm using the same version 2011, the software and the web plugin, and I checked the firefox web plugin folder and there is the LVRT2011.so. I dont know what to do.
(4,424 Views)
Hi Tolima,
this looks like a path issue. I suppose you don't need create these directories. If I am not wrong the default directory for Mozilla Firefox on OpenSUSE is /usr/lib/mozilla/plugins.
Try this and return me the results.
Ricardo Ramos
Account Manager
(4,411 Views)
