The following file(s) are not found on the system: <Not A Path>
I have tried doing several Installer builds on various machines, but I have got the following error:
<Not A Path>
<Not A Path>
Details:
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_PreBuild.vi >> CDK_Engine_FileExists.vi
I have done several installations before on the same project, I am not sure what I could have done for this to suddenly appear.  Has anyone else seen this?  How can I find out what files the Installer is looking for?
(3,152 Views)
Accepted by cbgrove
(3,142 Views)
Thanks!  That helped.  When I did a diff between the broken project file version and the repaired version, I noticed that the FileInfo[].TypeID for two files were missing in the broken version.  Part of what the TypeID defines in a path name, so I guess the error message would make sense.  Example:
                    <Property Name="FileInfo[1].TypeID" Type="Ref">/My Computer/Build Specifications/ABC</Property>
(3,104 Views)
