11-16-2009 03:05 PM
if i try to start LabView, the following warning occures: "Unable to open Rescource Files"
effect: I can't use LV
How can i solve this problem?
Solved! Go to Solution.
11-16-2009 07:17 PM
Did you searched the forum? Study all the threads here.
Post back if that didn't helped.
I am afraid repair or re-install LabVIEW is the only option.
11-16-2009 10:32 PM
The "unable to open resource files" error message is often caused by moving files from where they were originally installed. Are LabVIEW.exe and the supporting files all in the same directory? Did you install to the default directory location (C:\Program Files\National Instruments\LabVIEW xx)?
Else try repair or reinstall.
11-18-2009 04:57 AM
