The following warning occures: "Unable to open Rescource Files"
if i try to start LabView, the following warning occures: "Unable to open Rescource Files"
effect: I can't use LV
How can i solve this problem?
(2,873 Views)
Accepted by topic author sindou
Did you searched the forum? Study all the threads here.
Post back if that didn't helped.
I am afraid repair or re-install LabVIEW is the only option.
(2,858 Views)
The "unable to open resource files" error message is often caused by moving files from where they were originally installed.  Are LabVIEW.exe and the supporting files all in the same directory?   Did you install to the default directory location (C:\Program Files\National Instruments\LabVIEW xx)?
Else try repair or reinstall.
(2,853 Views)
So what was the solution?
(2,829 Views)
